Need some help to find drivers
Hi friends , I need your help to find windows vista drivers for Altec Lansing ACS595 speakers , because I cannot adjust the speaker settings other than manually
It is important that we update or install sound and audio drivers for our system not just to fix any issues but to improve performance as well. You may go online and search for the right drivers of your device and the updates that come along with those drivers, however, it could be a hassle if you are not aware which to get since there are a lot of websites offering updates and drivers online. Nevertheless, here is one website that could be very helpful for you: http://xpdrivers.com/sound-audio/altec-lansing/_3_2406.cfm. It has Altec Lansing Sound and Audio Drivers that you can download, and it even has the option for you to search or locate the right drivers you’ll need.
