Need some help with Google chrome
I can login to my Facebook account but images on my profile is not loading properly.
Some images load others do not ,
Can anyone help me to solve this problem?
I think the reason behind this inconvenience is the poor internet connection. The connection may be interrupted while loading the page or The connection may be too slow to load that page. If this is the reason then you should talk to your Internet service Provider to speed up your line. Otherwise you should change your connection operator & take speedy internet connection.
The another reason may be Facebook's server problem. Sometimes it happens in Facebook pages for huge load on Facebook server. Or the picture you are seeing may be the original picture. There may be problem in your web browser also. You should always use the updated version of internet browser. Some pictures of your friends can't be seen by you because these may be not shared with you.
Check all the reasons mentioned above. Hope that you will get your desired solution.
