Need some help on my excel
I need some help on my excel spread sheet.
I have 10 columns.
I have to transfer these as 10 rows.
Is there any way to do this?
I have 10 columns.
Yes, it is possible.
At first, you have to copy the columns.
Then, go to another excel sheet, select a cell, click the right button and select the “paste special” option.
Now, give tick marks on the ‘Skip blanks’ and ‘Transpose’ options. Click Ok.
By doing this process you can transfer all columns in rows at a time.
To convert a file from column to row. Please follow these steps.
First, copy all the information that you want to convert.
Second, go to any available column, just right click and select "paste special".
Third, check "Transpose" then "OK".
Last, highlight again the files you copied earlier. Instead of copying it again, right click then select "Delete".
Just delete the entire column.
Best Regards,
Jerameel Cyrus Tubon
Hi, Brayen Jones,
I think your problem is solution able, make the copy of your columns, open another excel sheet, then click in the right button of the excel sheet then you have to click on the paste special option, that it!
You can also search in the Google or Windows live search for better solutions.
Best Regards, Sumon Khan
Hello Brayen,
To transfer the data between columns and rows, you will need to follow the procedure that follows:
Carl
I read your question.
Your solution is at first select you 10 columns and then copy it and then go other sheet then click paste special and then check transpose and click ok.
Notifications
