I keep getting this error message every time I close open office writer,please help me to stop getting this error message
Program Compatibility Assistant
This program might not have installed correctly
If this program didn't install correctly, try reinstalling using settings that
are compatible with this version of Windows.
Program: Unknown Program
Publisher: Unknown Publisher
Reinstall using recommended settings
This program installed correctly
Need some help with open office writer
As you can see, the key to the solution of this problem is in this sentence: ‘’ …compatible with this version of Windows’’ So, basically, you encountered a problem with non compatible version of Open Office and Windows. Judging by the skin of your screenshot, you are using Windows 7 which sometimes have problems with some aspects of Open Office. If you’re not willing to uninstall Windows 7, the best solution for you will be to try to find some version of Open Office which is compatible with Windows 7, delete all of the previous installations and start again.
Hope this helps.
