Need some help regarding android
Hi guys , I just bought a Samsung Galaxy S2 last week, So I want to create my own theme, I need your help to find any software or online solution to create my own android mobile theme?
Can someone please help
Hi emerald ,
You need to learn android programming in order to create your own android application , themes etc.
Its not that easy, If you have already learned JAVA programming language then you do not need a tutor, Visit this website to get to know all information regarding the creation of android apps and all other related to it.
You will get the tools also there to create the android apps.
First you need to download Eclipse IDE (integrated development environment) this is where you do the create Android applications after downloading it , you have to download the android SDK and then in which android you are using , now you have Samsung galaxy S2 so yours is Android 2.3 ginger bread, so download that package.
Now after learning and doing all these you can create your own themes, application etc .
