Hi friends , Someone tell me why I am getting the error “SRS audio essentials encountered error… ” when I start the program, I can click “start service” ,but nothing happens,If anyone has the answer, I would be very grateful
SRS Audio Essentials encountered an internal error. This can occur when required system services have been disabled.
Click the 'Start Service' button to remedy, or click 'Cancel' to quit the application. |
Need some help regarding SRS Audio Essential
Hi Mary,
An internal error means a program is trying to use a memory block in the computer that is forbidden. Once this occurs, the operating system displays this error and the program stops working. This could be caused by anything.
To solve this problem, take the following steps:
1. Try upgrading your Operating system hence your antivirus software.
2. Try uninstalling and reinstalling SRS Audio essentials.
3. If all these doesn't work, then the last thing you can do is to restore your system to a previous time.
I hope I have provided a working solution.
