erica jonas
Posted on - 03/09/2012
Hi guys ,
My computer worked properly a day before but today when I start my computer my desktop background is all black and displaying error message “you may be a victim of software counterfeiting ask for a genuine windows ”
Can someone please help me to solve this problem ?
Need some help regarding windows XP
Hi there ,
The major flaw in your question is that you didn't specified which OS are you using , Windows XP or Windows 7 ?
Please note to all those who post questions here , Please ensure clarity and specify in detail all the information regarding the problem so that it would be easy and specifically we can solve your problem.
In both operating systems and EXE file in C: – windows > system32 and some dependent dll files are causing this popup.
Please note that you are actually a victim of software counterfeiting and you must definitely buy an original windows version..
1. Assuming your OS is windows 7 :-
Go to this link to download the WGA removal tool , install it and run it according to the steps specified in the tool to successfully remove that :- http://www.softpedia.com/get/Tweak/Uninstallers/RemoveWGA.shtml#download
2. Assuming your OS is Windows XP :-
Hi dear,
It seems that you have installed a software that is not supported on this Windows platform, or has a lot of viruses that have spoiled the system files.
You do not need to worry about it. Just restart your computer and press the F5 key on the very first screen.
Then, choose safe mode. Your computer will run in safe mode. Now, type "appwiz. Cpl" in RUN and press OK.
It will open the Add/Remove Program, just uninstall your recently installed program, and restart the computer.
