erin hart
Posted on - 03/09/2012
Hi guys,when I try to install Zune (Music and Video Software) it gives me this error code “
Setup must stop because the required package 'Zune' failed to install ”
I have no idea about this issue , If anyone has the answer to solve this issue, I would be very grateful
Installation Failed
Setup must stop because the required package 'Zune' failed to install.
Custom Action 22:45:44.109: Operation 'InstallDriver' has finished with result 0x80070643.
Custom Action 22:45:44.375: Operation 'RemoveDriver' has finished with result 0x80004005.
DIFXAPP: Rollback failed with error 0x2
Error code: 0x80070643
https://support.microsoft.com/en-us/help/11696/windows-phone-7
Need some help with Zune installation
Getting the error “Setup must stop because the required package 'Zune' failed to install” message is very annoying however one reason why this occurred is because the updates that are needed by the Zune software were not available when the software was initially installed or downloaded.
To have this resolved, you will need to download all the required updates for the said software in one package. Before downloading the Zune software and updates though, please make sure that you meet all the system requirements for Zune to work properly on your computer. I would suggest that you go to https://support.microsoft.com/en-us/help/3096659 for the steps to resolve this issue.
