I need to buy a ups for my work with maximum backup. There has been a recent problem with shutdowns and I need my PC running continuously for a long time. That is why I need a UPS with maximum backup. I do not know much about the UPS and I do not know what kind of back up times are available either. I need someone to inform me about the current backup limits of UPS.
Bryan Edwards
Need some information on UPS=urgent
If you mean UPS to run single computer systems than 600 volts amps are more than sufficient. UPS gives short term power when the main power supply source fails or if there is a surge, sag or spike. Warranty on UPS also varies and is dependent on the machine, if it’s a single phase or three phases.
Mirotek, APS are some of the leading manufacturers of UPS.
Hope this site helps you to select your UPS.
They have reviewed as well. Please go through the same.
Tripp Lite's BC600SINE UPS system provides long-lasting battery backup, it’s 97% efficient to get your work done, it comes with 3 UPS battery supported outlets,3 surge only outlets, and it has an 18 minutes battery runtime.
Tripp Lite's SMART1200LCD Line-Interactive Digital UPS System offers voltage regulation, surge suppression and long-lasting battery. It has NEMA 5-15P input plug and 8 NEMA 5-15R outlets, USB, DB9 serial, TEL/DSL/ethernet protection, Rackmount kit, 1200VA / 1.2KVA 2U rack/tower 120V line interactive UPS with LCD display, it's good for preventing loss of data and shut downs.
CyberPower Intelligent-LCD series of UPS battery, which has input voltage level, output voltage level, automatic voltage regulator, remaining battery capacity, estimated on-battery runtime, device total load level, output frequency, on battery alert, overload warning, fault condition notice, and silent mode display. Best used until the battery time light runs out.
There is also an APC UPS which comes with battery backup with surge protection that allows you to save all information before it's actually turned off.
