Need some offsite data storage solutions
Hi expert, I need some offsite data storage solutions for following facts.  How to increase the speed and reliability of recovery, the restoration of data and How to minimize the burden on your administrative and management  teams.  Suggest some valuable solutions to fulfill above facts.
Answered By 45 points N/A #186326
Hello Ericson,
It seems you need an offsite data storage solution. Offsite data storage is used to protect critical data by sending it away from the main location which is a part of disaster recovery. Hybrid onsite and offsite vaulting could be the solution to your problem. It involve a combination of local backup for fast backup and restore, along with Off-site backup for protection against local disasters. Hybrid Online Backup works by storing data to local disk so that the backup can be captured at high speed and recent backups are retained locally, to speed data recovery operations.
I hope this helps.
