Need some suggestion about network security
Hi everyone, I am running an organization.
I need a strong antivirus for my server connection. Is alt n mdaemon antivirus fine for my server?
Please reply me with some suggestion,
It is very important to use antivirus software to protect your PC. And if you are running an organization than it is even more important because you will have many people working on your network so viruses can spread quickly in offices. Therefore, it is best you install a very strong antivirus.
Try installing one of the following:
1. Kaspersky Anti-Virus
2. Norton AntiVirus
3. Anti-Virus Guard (AVG)
4. Avira
To install any of these just Google their name and go to there official website. In the website you can find instructions on how to install the software.
Hope this helps!
It is very vital to use antivirus software to shield your computer. If you are running an establishment than it is even more significant because you will have many people working on your network so viruses can spread speedily in offices. as a result, it is best you install a very strong antivirus.
Install one of the following Antivirus. To install any of these just Google their name and go to their official website. In the website you can find instructions on how to install the software.
Hope this will be helpful you.
