I've been improving my company's systems just recently. My hr department seems to have some serious problems regarding its management. Can you share some templates for hr management system? My company is just an average one. Templates that fit medium-sized companies would be perfect for our situation. Please do help me with this problem.
Thanks in advance!
Need some templates for hr management system
Hi Jurita,
There are numerous HR Management templates available in the online market (some free and some paid as well). But it's always a difficult task to choose one that best suits and fulfill our requirements.
Based on what you mentioned, I am listing some that might be suitable for your organization.
Have a look at these –
Hope you find this useful.
There is a lot of software available on the web either it is a freeware or for purchase. As I understand your need, it is to improve your HR Management system. You may check on the two sites which may be applicable to your needs:
Technology Evaluation Centers – a site to buy a software
Free Website – many freeware to choose as stated
I would suggest to have your HR Management System customized. With customization, you need not employ additional staff and you can have all processes customized according to your needs for the present and the future. Known financial software in the market is SAP and Microsoft Dynamic GP. You just need to customize it into your budget or purchase what you only need.
