Need some tutorial about alcohol 120 52
Hi everyone, I have many CDs & the DVDs in my own & I want to burn them by alcohol 120 52 software, but it is not working. Can anyone give me some tips about this? Thanks!Â
You could always go the official website of alcohol soft. Please see the following link:
http://support.alcohol-soft.com/en/support.php
In this page you can also see the manual. This will show you step by step instructions on how to use the software, You could also get answers to any problems that you have while working on the software. This is probably the best way to learn more about the software.
Hope that helps!
If you want to burn CDs and DVDs with Alcohol 120%, check that your computer meets the requirements. Like with any other application you install on your computer, the software has to be compatible with your system before you can use it. Also, since this is a burner used to burn CDs and DVDs, you have to have a compatible CD or DVD writer.
Even if you have a compatible system, if your machine is not equipped with a CD or DVD writer, you still won’t be able to use it. An ordinary optical drive like CD-ROM or DVD-ROM is not designed to burn discs and can’t be used to burn CDs and DVDs. To download the latest Alcohol software, go to Alcohol 120%.
The latest version supports Windows 2000, Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows Server 2003 both 32-bit and 64-bit. It requires 700 MHz or faster processor and 32 MB RAM.
