Jem Mandap 50 points N/APosted on - 04/01/2013
I am using Ubuntu 11.05 OS version in my laptop. I have m2ts files to convert. I want linux edit m2ts files and transform it. So I need some converter or tutorial for do it. Please suggest me some links or URLs. Thanks.
For convert the m2ts files you need to have a software. You can do this on ubuntu. For more help you can just follow these steps: Just copy all the streams and output them in an mkv container : ffmpeg – i input.mt2s – scodec copy – acodec copy -vcodec copy – f matroska input.mkv. While you done it no information is lost or re-encoded. You can search for videos on youtube. Or just watch this video:
If you want to convert your m2ts file then you have to use a third party software so that you can convert your file and transform them. As m2ts format can be easily converted in to your desired formats like AVI , MOV , FLV etc.
For converting them you need to use the WinX HD video Converter it is one of the great video converting and transforming software for m2ts formates. You can buy it from the below link.
1....
