Need Steps On How To Fix Windows 7 Errors System Files
I think system files on my PC had been corrupted and causing some problems due to that. I want to know how to fix Windows 7 errors for system files. Help me guys.
To fix system files on your pc-
1. Go to start
2. And then type cmd
3. Right click on command prompt and run as administrator
4. Type the command sfc/scannow and hit enter
This command helps you find errors in system files and fixes it automatically. So your problem is solved.
There are different kinds of errors you may encounter on Windows 7 and there are different solutions as well. So, depending on the problem, the solution may or may not apply to another problem. Like for example, if you cannot boot your computer properly like it keeps restarting, try booting it using the last known good configuration option.
Start or restart your computer then press F8 before the Windows logo appears. In “Advanced Boot Options” screen, scroll down and select “Last known good configuration” then hit Enter to boot. Another problem is when you keep receiving errors in Windows while using the computer. Here, you can try the System File Checker utility.
Press the Windows key + R to bring up the “Run” dialog then type without quotes “sfc /scannow” then hit Enter. Insert your Windows setup CD or DVD when you are prompted then continue. Wait until it is complete then restart the computer. You can also download PC Tools Performance Toolkit to check your system for other problems.
You can also use this to perform maintenance and optimization on your computer.
