I have a Windows Phone 8. A friend told me that when I used One Drive, the Auto-Upload feature will filled my storage. I want to know if it's safe to enable this feature. I have a 4GB storage on my device. Can I perform an update considering the storage size? Please send me some guidelines on this issue. Thank you.
Need Storage suggestion in window phone.
Windows Phone 8 includes an app called Photos. This app will automatically upload all your videos and photos to your SkyDrive account by default. This automatic feature is good at times but will consume your entire data plan unless you have an unlimited data plan. But for users with limited data plan, you probably want to turn off this feature.
To turn off the auto-upload feature, start the Photos app in your Windows Phone 8. See image.
After that, tap the small dots to open the menu then select settings. See image.
In Settings screen, scroll down to the bottom until you find the “Auto upload” section. This section lists all the apps that can be used to upload your media like videos and photos to the internet. SkyDrive has a separate section and the others are grouped in the apps section. Tap SkyDrive to access its features. See image.
On the next screen, select “Don’t upload” on both Photos and Videos section. When you are done, just tap the back key to return to the Photos app. The changes you made will be saved. See image.
If you are looking for additional storage for your windows phone than one drive is the best available option. As it is owned by Microsoft so Microsoft also provides his user the reliability and security. If you are using one drive you can keep your files in privacy just you have to do is sign in to one drive and there turn off the sharing from public to private. In order to keep your account secure put a strong password and follow the two step verification process. For further information visit this link.
