Hello all,
Today I came here to discuss with you about the antivirus ca internet security suite. I have always used kaspersky or bitdefender. But some days when I search on internet then I find the result with ca internet security suite 2008. I never used this antivirus before. And nobody in my circle have knowledge about it. So I came here to discuss with you about the antivirus its advantages disadvantages. So please share your view with this antivirus here so we can have knowledge about it as well.
Need suggestion about CA internet security suite 2008
Hi there George J Layton,
Just like all the other security tools, this one follows trends so it's offering the full package including anti-virus, personal firewall, anti-spam, anti-phishing and anti-spyware protection, parental control and mobile device protection. The biggest plus for this utility is that the suite offers some really useful tools like a data migration or incremental backup. The biggest minus is that it is not well tested by testing agencies so there is no way to know for sure if it will protect your computer completely or not.
Since you're already using Kaspersky that is well known and trusted software, I wouldn't recommend you the change of your security software.
Best regards,
Drake Vivian
Thank you for your question.
You can download the software from the following site totaldefense
The total defense Internet security Suite is one of the best antivirus software which achieves the VB100 certification test.
And also it gains the Global excellence Award in the Antimalware, antivirus and anti-spam category by the organization named Info security Products Guide. It’s user friendly.
There is no disadvantage of this software.
You can use it.
