Need Suggestion about Power Supply
Here is my PC specs:
Procie : intel core i3 2100
mobo : ASRock H61M-HVS
RAM : PATRIOT PSD3 8G 1333 KH (2x4Gb) DDR3
VGA : Digital Alliance GTX 550 Ti
Does it fit if I use PSU ENERMAX NAXN 550W?
Hello Samwatson.
Based on the technical specifications of the GeForce GTX 550 Ti, the card draws 116W maximum power. Â It also indicates that the Minimum system Power Requirement is 400W. Â You can check it out for yourself here:
https://www.geforce.com/hardware/desktop-gpus/geforce-gtx-550ti/specifications
I also made some power computations based on the hardware information that you provided and assuming that you have 1 SATA hard drive and 1 DVD R/W drive. Â The PSU wattage that you need is around 287 Watts only. Â You can actually check the power computations on your own using this online tool:
So the answer to your question is a definite yes. Â Enermax NAXN 550W is more than adequate for your needs. Â It still has enough headroom even if you decide to use an SLI configuration.
