V Gilden
10 points
Posted on - 07/20/2016
Hey all,
I have been using Laser Printers for a long time and now, I am looking for an Inkjet Printer that I can use for printing Envelopes.
Someone, give me suggestion so that I can find the Best Inkjet Printer for Envelopes
Need Suggestion For The Best Inkjet Printer For Envelopes.
In my opinion, you can buy Canon PIXMA MX922 to print the envelopes. It is a Wireless Printer so, there is no problem of wires. It comes at a nominal rate and you can purchase it for less than $100. It is capable of printing Envelopes and other such documents that you need.
You can use it for scanning, copying, and emailing the documents. You don’t have to buy a separate Ink Cartridge, you can run it straight away, once you install it.
 It comes with the features like Google Cloud Print along with Air Print and PIXMA Cloud Link. It also supports Mobile Printing.
You should go for this Printer.
