Hi there. I plan on buying an Apple computer. Can some suggest Apple computer models that would suit my needs? I need a gaming PC with at least 4 GB RAM, Intel Core CPU and 1 GB Graphics Card. Any suggestions would be highly appreciated. Thanks.
Need suggestions in Apple computer models
Hello Bennie
Looking at your requirements. The best Apple computer would be MacBook Pro with retina display. It consists 2.5GHz dual-core Intel Core i5 processor with mountain lion OS. It has 8GB of 1600MHz DDR3L onboard memory. Storage space upto 256GB and extendable up to 768GB. Intel HD Graphics 4000.
Hope You like it.
Thank You.
I believe what you need is the Apple MacBook Air. With its powerful graphics and faster processor, gaming will be an amazing experience for you. It's got the new Intel HD Graphics 4000 which offers up to 60% faster graphics. It supports up to 8 GB of memory
It's also got a sleek design which is ultra thin and light
Hope I helped you make the correct decision!
Hi Bennie,
I think that you need to buy  Mac Pro Apple PC,because it has the things that you are finding which are the 4 GB RAM,intel core and more than 1 GB Graphics card.If that's just what you need,well,better buy what i have sugggested to you.But I know that you are stiil confuse because many suggested a nice Apple computer for you,but i think I suggested better than the others.
