Can anybody suggest a good handwriting app for Acer Iconia Tab A500? I have bought several of those note taking applications and they all worked poorly for me. Either my pen strokes get suddenly shortened or cut in. I’m not sure if this is because of the Stylus i’m using. I have the Acer Stylus that came with the tablet. Any help, do please extend, as I really want to continue taking notes on this Tab.
Need suggestions for handwriting app for Acer Iconia
Please try my experience
I have found an app that takes hand writing on the Acer nearly perfect. It is called Whiteboard Pro.
Write fast or slow and I always get good results.
So, it's not so much the touch screen, as I first thought, but the app that makes the difference.
Greetings,
First of all thank you for selecting our site for your query here is your answer
I will suggest Genial Handwriting or Handwrite. They both are free, I personally think it works really well, smooth interface.plenty of options on sharing the notes (email, evernote, dropbox, etc.) and further it also depends on your handwriting recognition and speed of writing.
Regards
Lopes Natanne
