Need Suggestions for installing ACG Antivirus Software
Hi Fred,
You don't have Antivirus software installed in your computer? Well you are in right place to ask. Im working in the computer shop for a year. Yes you can install downloaded AVG antivirus program for the meantime its a trial version for 30 or to 60 days free after that you need buy the full version antivirus.
I can suggest need to buy full version, so that you don't need to install and reinstall over again hassle free.
And besides your fully protected at the very beginning while the trial version is only limited protection unlike the full version is full protection.
