Hey everyone,
I am a fond lover of multi-monitors. That makes the work easy and saves time as well. I do not have Windows 8.1 on my PC, so I would need separate Software for this purpose. So, someone, suggest me the Best Free Dual Monitor Software.
Need Suggestions Regarding The Best Free Dual Monitor Software.
Hi, I would suggest you to upgrade your Windows at the first place to stay away from the problems of searching and downloading separate Software. In case, you do not want to upgrade Windows then, you can download Dual Monitor Tools from
https://sourceforge.net/projects/dualmonitortool/.
 This is a tool designed for Windows users with Dual or Multiple Monitors. This software has hotkeys that allow you to move the windows around and restrict the movement of the cursor between the two screens. It allows the user to quickly switch between the screens and launch applications on a particular window. It does the spanning of the Monitors and set different wallpapers on different screens. It can also capture pictures on one Monitor and display it on the other one.
