Need tips for web design software suggestions and guide
Good morning to everyone. Can you suggest any other web design software that you have used which is quite comparable to Dreamweaver but has better or more features and tools? I was thinking of one that has the drag-and-drop features and an easy to use interface. Please suggest. Thanks for the help!
Best Answer by Thornton Patricia
Answered By 0 points N/A #148869
Hi Isaac Ashton,
If you want to create and maintain a website, I will give you a site link. If you visit this site, you can get a completely new edition that provides a strong foundation for planning, designing, and maintaining attractive and functional web sites with the latest tools.
To start designing your website you visit in this site.
Answered By 0 points N/A #148870
Comparable to your Dreamweaver web designing software there is another named, Aptana Studio which I'm using right now. It has a wide range of powerful authoring tools with a collection of collaboration services and online hosting. It also includes support for CSS, PHP, FTP, HTML, JAVASCRIPTetc.its interface is also user friendly.
Answered By 0 points N/A #148871
Web design software nvu having drag drop features like Dreamweaver and it is free to download go to net2 site and look for nvu software then get link and download then install otherwise try kompozer tool works same as Dreamweaver support for css code generation and able to work with templates, different websites and easy to follow editing html code.
Hope these shall helps you
Thanks
Answered By 40 points N/A #148872
There is a Techyv article which one will be helpful you too. From here you will huge information about web design software.
Web Design software you can definitely use
