Need To Download The Windows 7 Professional Japanese Language Pack
Hi, I am using a Windows computer and I noticed that it does not have any Japanese language pack installed by default. Since I need to use it, can someone explain how I can download the Windows 7 Professional Japanese language pack?
Answered By 15 points N/A #278041
First, you need to make sure that you are using either the enterprise version or the Ultimate versions, since they are the only ones in which it is possible to change the language through an option present in the control panel.
Since your question does not mention the version you are using, I am going to give you another option to install your desired language pack.
You need to install a “language package”, which you can do from the following link:
http://www.froggie.sk/7lp64sp1.html
Just select the language you want and install it in your system.
