Need To Learn Windows 8 Mounting Iso
Hi, I heard about a feature using which I can mount iso directly. I am using a Windows laptop and have recently upgraded to Windows 8. I need to learn Windows 8 mounting iso.
I can understand your situation because I used to be a heavy user of the MSDN software, and I realized that everything I downloaded through the software was downloaded in a format called iso.
Thus, a lot of time was wasted on extra steps whenever I wanted to burn the downloads to a CD.
But when I got Windows 8, I started “mounting” the iso files.
This is done as follows: On the iso file, use the mouse to make a right click. From the available options, click on “mount”. Then, you should see all the files which have been extracted. Now, locate the setup.exe file. When you click it, the software will be installed.
If you find pictures easier, you can try to understand the steps through the pictures given below:
