Hi guys,
I need to upgrade from Windows 7 Pro to enterprise, as I have heard its performance is much better and also it has many security enhancements as well as faster speed. Can you tell me if it’s possible to upgrade and how to do it?
Need To Upgrade From Windows 7 Pro To Enterprise
Normally, it’s not possible to switch between versions like this, but there is a small workaround that I will be sharing with you. But before trying that, I suggest you create a system restore point and also backup all your data, in case this does not work.
Now, just take a reference of the below image to change the registry keys as shown in the picture. Then, use the SP1 installer to run a repair install. This will upgrade your version.
