Eddels
Posted on - 07/26/2016
Hello all,
I want to export my Exchange 2003 mailbox to a PST File. I need a tool to perform this task in a simple way. I am not technically good, so someone, please suggest me an Application for Exchange 2003 Export to PST.
Nabeela
150 points
Need A Tool For Exchange 2003 Export To PST File.
I would advise you to download Exchange 2003 EDB to PST 7.4. In my opinion, it is the best Converter tool for converting EDB to PST. You can download it from
https://www.windows7download.com/free-win7-exchange-2003-edb-to-pst/.
 It can solve all the corruptions that are related to Exchange Servers. After downloading it, follow the On-Screen instructions to install the Software. Run the main file. After that, you will be able to export your Mailbox to a PST file. This Software has received positive reviews from people all over the Internet. You should go for it.
