Need total gaming experience for iPad
How long will the battery last for iControlPads?
Is the battery replaceable when it starts to show signs of degradation?
Hi Hannahwtc,
The battery for iControlPads usually boasts battery life of up to 10 hours of surfing the Web on Wi-Fi, watching video, or listening to music. It could last for 9 hours of Web surfing over a data network if it is a 3G-equipped model.
Usually a battery that cannot be charged fully is often times a sign of a weak battery that has a degraded to the point of needing to be replaced. It could still hold for a weak or low-level charge but it cannot be recharged back to its full strength due to internal wear and degradation. Technically, if the battery of the computer shows internal wear and degradation it would lead to battery fails then your computer might forget its BIOS and stops working properly.
Hope this could make you decide if you needed to change the battery of your computer.
The iControlPad is a Bluetooth game controller which you can use on your Android and iPhone Smartphones, and other Bluetooth-capable devices. This Bluetooth controller was originally designed for the iPhone handset which uses a dock connector. But due to some licensing issues with Apple this design didn’t stay longer. Because of that, the team who designed it was forced to reveal the controller’s Bluetooth support which they have been keeping a secret. Not because its name starts with “i” it is already associated with the iPhone. You can actually use it on any devices.
You can use it on computers running on Microsoft Windows, Mac OS X, or maybe Linux and mobile handsets from the early Nokia N900 to Android Smartphones, and more. The life of the battery is good since the 1350mAh battery can be recharged easily using the mini USB cable. There is also an LED indicator at the bottom of the controller that will let you know when the battery is already running low. And also, if while using it your Smartphone becomes low in battery, you can also connect your mobile phone into the controller to recharge.
The iControlPad Bluetooth controller
Thanks guys, all your comments were helpful especially the ones from Sharath Reddy. After reading through the comments, I learnt a few things related to my question including tips on how to use IControlPad that I previously did not know about. Also I did not know that the LED indicator found at the bottom of the controller is supposed to help us in tracking the battery usage to avoid instances where we run out of charge. I have leant new things that are very helpful.
Notifications
