Mona Green
Posted on - 12/12/2011
Can you give me any help on how to get rid of the error: atidvag? I only install two new games on my computer, Sims2 and the Sims2 University, but there was another game installed and my PC just froze. That was also when I got the atidvag problem with a message that says "the file is damaged" or something like that.
Let me know how to fix this please.
Need troubleshooting tips for atidvag error
If you want to remove the error to your system or to your software, just try to download the Error Repair Tools to your PC then after you download the application. You just simply install that to your Unit and try to restart your machine to be sure and to avoid any error or maybe an corrupted files, after restarting the unit. You must start scanning the system, then after that you must repair the found errors to your PC. Try to scan the Unit to check if there an infected file or maybe an corrupted from the viruses and spyware.
Ben
