Hello Techyv users,
I am in need for face logon advanced software for my Windows 7 PC. Software should be accurate and capable of not being bypassed through any infiltration. I need it secure my PC from unauthorized access.
Need very good face logon advanced software for Windows 7
Hello there! If you are looking for a reliable but secure Face Log on software, you should check out KeyLemon. It uses face recognition technology to detect specific areas in your face and matches it with the one that was set. You can also use it as a substitute for your log on password in your Windows account when accessing the Log on Screen. You can also purchase the Bronze and Gold versions where they offer more features than the free version.
Hello Acilis,
Here is another face login software.
Please be advised that once an intruder gets physical access to your computer or router even a face login software won't be much help. If you have sensitive files, encrypt your drives.
Don't let anyone have access to your computer unless they really have to and are supervised.
Sincerely,
Luz M Terry
