sherrywcarr
30 points
Posted on - 02/05/2013
Hi experts! I’m looking for a video capture software freeware. Does anyone know a good software I can use? Please need some lead to do it as well as to the procedure using the software you know. Thanks.
In need of a video capture software freeware
Hi Sherrywcarr,
Most of the good video capture software like Camtasia Studio and Debut Video Capture Software Pro version are not freeware and you need to buy them. These paid software have lots of extra features that give you quality output and that's why their price is higher. But there are some very good open source or freeware too that I have used and got a very satisfactory result. Â Â
Some of the freeware I am using right now are:
CamStudio – which you can download from and Ezvid and you can download it from  http://www.ezvid.com
The above two freeware are very good and also serving my video capturing purpose well.
Hi, well, if you are talking about video capturing software than definitely you can try camstudio.
Its totally free and can be used in many purposes such as creating demo videos, capturing picture of your desktop and much more.
The installation process and the interface is quite easy and user friendly.
Here is the link.
Enjoy.
