A need of Visual Studio 2010 cleaner
Anyone knows a reliable Visual Studio 2010 Cleaner. I’ve been using Visual Studio in some of my projects and as we all know they clutter and leave some temp files. Need help with this.
Answered By 0 points N/A #158243
Hi Teresa Duncan,
I guess you are running an older code version that you want to debug. You can rebuild your project. I have suggested to you, try visual basic 2005 because it easy for you to clean your unwanted files simply choose a clean solution from building menu and all the unwanted files in your whole solution will be removed quicker and easier. Go to the solution explorer, just like that.
Thank you.
Clean Solution
