Need web creator image gallery for Mac.
Hello, I am trying to create a personal website in HTML. So I need a web creator for Mac is having a large image gallery. But I don't know from where I can get it for free.
Hello Dear Friend,
There are many software's from which you can create images for your website easily.
You do not need Adobe Photoshop to resize it or to make some changes. These software's are very friendly to use.
These software's have very easy user interface. There are two software which you can use for this purpose.
The software is “iGallery”. This tool is an easy and quick web photo gallery creator.
You can also download it free from here.
Hope this will help you.
Good Luck!
Dear Peter Gonzalez,
You can use the software below-
Download any of the software from the above links given. Then install it in your PC and run it. After that you might be found your solution.
With thanks-
Stonjhon David
Hello Peter Gonzalez,
Using web creators is best idea to create any kind of website as creating a website is very time consuming, critical and tedious job.
But web creator tools do it with great ease, you just need to have your requirements on your hand and learn easily about web creator tools and you can build your website.
Use this video tutorial on how to create a website with web creator.
http://www.karelia.com/products/sandvox/
Mac web design apps for beginners
Best Macintosh Web Editing Suites
Hope this answers all your questions.
Thanks,
