Need a Yamaha xg 50 on Windows 7 Plugin
I have been working on some sound files in midi format but recently they Don't sound properly I have heard about Yamaha xg 50 on Window 7 plugin which can ease to use to solve this issue is it true or do you have some other solution over it
Answered By 0 points N/A #198592
Hi Stewartyimothy,
With the help of  Yamaha Software Synthesizer S-YXG50 you will able to play  MIDI song files on any machine without using a hardware tone generator.
Its high fidelity sounds and it is pretty user friendly, match the sounds from an authentic tone generator, are based on and realized by highly advanced MMX technology. This S-YXG50 will let your computer to be a potential music synthesizer.
You can download it from here.
Hope it helps.
