Need your help with error code 13
When I open ncsoft launcher to play the game, this error code 13: (ProductConfigurationLoadError) occurs.
Please see the image below for more details. What do you think is the problem?
Do I have to reinstall the launcher?
Give me some of your suggestions.
Thank you!
NCsoft Launcher Update Error
Error Code:13 (ProductConfigurationLoadError):
There was an error loading the product configuration file
'C:gamesNCSoftLauncherConfigDefaultNCPatcherConfigProductsN
CLauncherMainNCPatcherProductConfig.xml'.
Please make sure the game is properly installed.
Error Code 13 OK Exit"
Best Answer by Ratyr patsr
Answered By 0 points N/A #152241
Such an error occurs mostly due to an invalid or non existent file.  The file that is shown over there may not be present in the installer, or has been deleted after the install or some other software might have deleted or corrupted it that it is unable to open. You must have antivirus installs in your computer, that be the latest one. All you need to do is to uninstall the software. If some error occurs during installation, then open regedit.exe from command prompt then delete all registry entries of the software. You can reinstall the software for the purpose of reinstalling the same.
Answered By 0 points N/A #152242
The reason for this error is most likely a framework issue. It can be resolved by uninstalling the .NET framework and reinstalling or upgrading to the newest version of it.
Another thing you should ensure is that the XML file is not being used by another program that could be interfering with your use.
Answered By points N/A #152243
 I am sure your PC has registry problems. It is very easy to fix NCsoft launcher update error. There are 3 steps to fix NCsoft launcher update error and follow these steps:
1: At first Download a registry cleaner & install it.
2: Then Open the registry cleaner & scan your computer for free.
3: Next Click fix button & you have done.
Download the top NCsoft launcher update error repair tool.
Now enjoy your game!
