I need your help on windows mobile 61 utility ssh. Do you know that the free tool acting as a Telnet / ssh client? If yes, please let me know the tool name and the location I can download and install.
Need your help on Windows mobile 61 utility ssh
Hi Nicholas,
I have something interesting for you, you can get the tool that you are looking for on the internet and it is absolutely free.
The free tool that acts as a Telnet / ssh client for windows mobile is PocketPUTTY, this is a wonderful tool that can be downloaded for free and then it can be installed to the windows mobile easily and it is very user friendly to use.
All that you require are,
1. Windows mobile with 5.0 OS
2. Minimum 1 MB storage and memory.
3. We also need a network connection.
This tool can be used to configure, SSH1, Perform Tunneling, SSH2, Serial, Telnet, Color terminal emulation, Private Key Authentication.
You need to use the following link to download the tool to your computer and then transfer it to the windows mobile.
http://www.pocketputty.net/download.html
I hope this has been helpful.
Bell Keny.
points
Unfortunately the pocketputty website is gone, does anyone have it?
