Needed Atlas sprite animation tween
I am using win 7. For win 7 I need the software of atlas sprit animation tween for different effects and animation if any body have working URL of that software please give me so that my problem is solve.
Good day,
There are many sites that offer a free download of Sprite Builder. I recommend you to go this page: http://www.freedownloadmanager.org/download/atlas-sprite-animation-tween-5348726.html and you can select what version of Sprite Builder you want, but I suggest you select Sprite Builder 1.0.
Thanks and best regards.
I wasn’t able to find a sprite animation builder or creator developed by Atlas but there are other software that are similar to the one you are looking for. Some of the versions of sprite animation builder is listed below. Just check them and see if they fit what you need that can be used as replacement for your Atlas sprite animation tween.
