Needed Error Code 0xc000021a Solutions
An error code 0xc000021a flashes on the screen whenever I try to proceed to an application. This has happened ever since I have enabled driver signature enforcement. Any solutions to this error code?
Reboot the PC from Windows. Just hold the Shift key and click on the Restart icon. If you can not operate the Restart icon on your system, then you may need to boot it through a Windows bootable USB. It will take you to a new screen. Select Troubleshoot. For accessing the advance tools, from the next screen that will come, choose only the Advanced option. In the startup screen, there will be varied correct seeming choices to select from. Hold F7. It will be labeled as Disable driver signature enforcement.
