Needed Ftp client and html editor
I am making my web. I want to edit my HTML page for that purpose I needed two program FTP client and HTML editor please tell me how can I download these program from internet free of cost?
From my own experience I can suggest you the best FTP client is FileZilla and the best HTML editor is Dreamweaver.
FileZilla you can have from the below link:
https://filezilla-project.org/download.php
And Dreamweaver you can search from the below link:
http://www.adobe.com/products/dreamweaver.html
Wish you a very happy using of the software.
If you found any problem with the links then please go to Google and search for "Dreamweaver" & "FileZilla" download.
Good luck.
There are lot of HTML editors available, but the most flexible ones are paid. If you are looking for a free html editor, you could use Eclipse IDE, which is free and open source, and for the most part, at par with other development software. But if you are looking for an HTML editor on the go, you may want to look into online html editors and IDE's available in the internet.
An example would be https://shiftedit.net/login for HTML editing, as you can even use your smartphone for this web application. For your FTP Client, I would suggest WinSCP.
