Needed Info: GPS mobile application
Can I use an application to check a trail via GPS on a map? Suggest an application that works offline with the good user interface. I tried using MotionX GPX but that does not suffice my requirements.
Yes there are a lot applications that can be used to check trail via GPS on a map. There is an app which I found best for my android is "My Trails ". You can download this app.
I found it very useful. I hope that this will work best for your case.
Thanks,
Junaid Fateh.
Hi Eugene Wood,
There are 1000s of applications out there in millions of android apps in the android market. I searched and used many softwares but was not at all satisfied and until I found this software. There URL for downloading it to your android phone is.
Just go to it and download it to have access to all the feature of trailing. The app name is Mobile Tracker Free. It can record tracks, view statistics, search, import etc. Many features are there. Just download it and start using.
Hope that helps solve your problem.
Notifications
