Needed: .net element to upload multiple files
I am looking some .NET element by which I can upload multiple files. From Internet I have downloaded many, but none are up to the marks. I want it for very light software with very simple customization. And I can access the source code to modify as I want. Waiting for you suggestions.
Answered By 20 points N/A #108223
Hello Luna,
You will need to get the .NET Framework that is compatible to the operating system that you are using and the one that is the latest so as to get faster services when it comes to uploading your files.
Just check the specifications of your computer and then  Google for the .NET Framework that suits those specs. For instance, if your computer uses windows XP, Google for the latest .NET framework for windows XP and then download it. Install it on your computer and see the speed at which the files will be uploaded.
__
Regards
Mahesh Babu
