hazelwlee
10 points
Posted on - 10/13/2012
I am using iPhone 4.
I want to use picture art smart phone on my mobile I want to  free download it from internet but I could not found URL of that Application if anyone knows about working URL of picture art smart phone then please give me.
Needed pics art smartphone 4 iphone4
The greatest way to get it is downloading from iTunes. Go there and collect it easily.
 Instagram is one competitive photo editing software for iPhones.Â
Get it from – https://play.google.com/store/apps/details?id=com.instagram.android
You can also try to explore for more versions and secured software.
Or you can go directly to your iPhone 4 and search on the App Store.
Hi, Hazelwlee,
You can try out the PicArts Photo Studio for the iPhone for free. But of course, you would get the other features if you purchase it for $0.99.
This application gives you the opportunity to put in effects in your photos giving it a finer, artsy look. This is compatible with the iPhone4, so no problem with compatibility.
Just search for PicArts Photo Studio by S Square System Limited on your App Store. Or you can check out this site first: https://itunes.apple.com/us/app/picarts-photo-studio/id514863914?mt=8
Enjoy.
