Needed software for cut edit audio mp3
If any body please tell me Is there any software from which I can merge, copy, paste cut edit audio mp3. I want to download that software free of cost please tell me name and Working URL of that software so that my problem can be solve.
Best Answer by Trotsky Timothy
Answered By 5 points N/A #139439
I would like to share to you this Mp3 editor it is a free software which you can edit MP3 files easily. You can insert, copy & paste, import songs from Mp2/Mp3, make CD burning, and more and this software has a friendly-user interface, you can download the software using this link:
 http://download.cnet.com/Free-MP3-Editor/3000-2170_4-75685443.html
I hope it can solve your needs.
Thank you.
Answered By 10 points N/A #139440
There are many free software’s which can be useful for you. Wave Pad Audio Editor, MP3 Direct Cut, Audacity, Virtual DJ Free Home Edition, Free MP3 Cutter and Editor, Power MP3 Cutter Joiner, these software’s are very helpful for you. You can download that free and that will fulfill your needs.
You will find these software’s from this link: https://en.softonic.com/s/mp3-songs-editing-and-cutting-software.
Thank you for asking the question.
Answered By 5 points N/A #139441
Hello Hollis Riley,
The software you needed is called mp3 Direct Cut. It will help you edit, cut, copy and change the volume of your mp3. This software can either be downloaded free or purchase from the internet.
Good luck.
