gyle kugler
90 points
Posted on - 10/26/2012
I am using MAC operating system. I want to download sound grabber in my window from internet free of cost I download it but it does not work in my operating system. If any body have sound grabber mac OS X then please give me and solve my problem.
Needed Sound grabber Mac OS x
Hi Gyle Kugler,
Maybe what you downloaded is software not compatible to your machine. Example, you downloaded a file which is compatible for Microsoft and not for your Mac. Anyway, here are some links where you can download it:
Download a full version then you will not face any problem.
If you want to download sound grabber then download iTube Grabber because It is the best software for you. It can grab all types of video. It works in any kind of format. There are also some other software like, Audio Grabber, Audio Hijack Pro.
Thank you.
Thanks for your comments, my friends. Trotsky Timothy, your post was magnificent and very helpful. You provided many suggestions for software: of those, I have downloaded iTube Grabber because it enables me to capture almost any audio and video stream. It is also free of charge and compatible with the Mac operating system. Superb solution, Trotsky Timothy. Thanks once more!
You can also use this Music Recorder app on Mac OSX to grab audio online.
