Harold Rudy
50 points
Posted on - 10/30/2012
I want Remote Webcam Software that allows some one to login and view a webcam remotely. There is no issue whether it is web-based application or software program, but it should be freeware. Also it has capacity to record and save from the live feed. If you are having any suggestions then reply me.
Needed to Use Remote Webcam Software
Hi Harold,
Your question is answered!
If you are looking for freeware Remote Software I recommend Digi-Watcher Webcam software. It enables you to record and save from anywhere in the world. It is equipped with motion detection, streaming, broadcasting, Video surveillance coupled with recording capabilities.
Click the Link below to download Watcher Webcam software:
http://www.digi-watcher.com/download.htm
I hope I have helped you.
Dear Harold Rudy,
One of the best softwares for recording and monitoring webcams is called iSpy, but it isn’t freeware. I recommend trying it. Its price is not that high. Its URL is: http://www.ispyconnect.com/download.aspx
The free software I can recommend is webcamXP which is very easy to use, and can be downloaded for free at this URL: http://www.webcamxp.com/download.aspx
Best regard,
Don Muench
