HI,
I am using win98 in my PC. I have some problem with my PC it take too much time to run any program or whenever i run program it take too much time on searching when it execute it placed a icon on my desktop I need win98 expert who solve my pc problem with in minimum time i pay for that if the expert if He deserve.
Needed Win98 expert for solving problem
Hi
I will certainly help you. The OS you are using is Windows 98. The OS is very old and outdated. It is not supported by newer applications. It also seems that you are you using a PC with very low specification. The problem you are saying is due to this fact. Upgrade to a new PC and all the apps will run smoothly.
Hi Halleleilani,
Thanks for sharing problem the major problem for the system to run slow is system configuration. You need to have minimum system requirements.
As you are using Win98 you pc should have minimum requirements as given below:
1 GB ram.Â
Pentium processor.
150 GB hard disk.
The above mentioned are upon your Operating system. For the other Os it will be different.
If you want to work properly then you need to follow these:
1. Change your operating system.
2. Upgrade your computer.
Windows 98 is very old and if you want to use software then you have to face problems because the software’s are upgraded.
Thank you.
