Needs Attention SCVMM Host Not Responding Status In The VMM Console
The VMM Server is not communicating with my host machine. Displaying a problem SCVMM host not respondingĀ attention needed. So give me a solution please thanks in advance.
Image result for SCVMM hostnot responding
Answered By 50 points N/A #295712
Check the status of a host by Opening the VMM Console, next view its properties go to Fabric view, right-click on the host which was experiencing issues then open its properties.Ā Next, go to Red exclamation category status which indicates the error details. Verify the VMM service account whether it is local administrators group on the host or not.
If the VMM is running as the local system account, then the account is a member of the local groups on the host. Now Add VMM services account to restricted groups in administrators because if the VMM service account was removed from your local groups then the issue could be caused by ā€œRestricted Groupā€ the group policy.Ā Create a new organizational unit in the domain then move your PC object to the new unit then configure the new organizational unit block to policy inheritance.
Check svchost.exe process in Windows Remote Management service because sometimes this problem occurs when the svchost.exe process is shared with the hosts. To resolve this configure the Remote Management service to as a separate svchost.exe process. To do thisĀ click here and check step 4.
