Needs to download rapidweaver 4 2 on my new pc
I just bought a Windows 8 pc and I am wondering if Rapidweaver is compatible with it. I previously used my MAC for this Rapidweaver 4.2 and I am wondering if I can transfer all my files and the things that I have already created on my MAC to my Windows 8 pc. I am not really sure if they are. Do I just download rapidweaver to my Win 8 and start over? Or is there anyway I can transfer everything and resume what I did on my MAC to my Win  PC.
Best Answer by Elmer Cook
Answered By 0 points N/A #140354
Hi Maggie Alley ;
Unfortunately RapidWeaver is not compatible with Windows 8 (or any other version of Windows). It is only compatible with Mac OS X 10.5.8 or newer. So to answer your question, no there's no way you can transfer your files from Mac to your new computer to resume your work.
Regards.
Answered By 0 points N/A #198268
If you are really transferring to windows 8 you cannot transfer the files yes. But there are a lot of alternative and different software's that might help you with the work that you are in line with. I can give you some of the software's that might help you with your work.
I can even site some comparison so that you can decide.
Click this link for comparison
Another software is
