Nero 10 – this program requires the file advrcntr2.dll
In my system, I installed Nero version 10 and tried several times to open it. When I try to open the .Vob file, the power dvd of Cyberlink gives me an error message " fatal error: installation corrupted, please reinstall Nero".
I used another application program to open the same file. Now it gives me the message – this program requires the file advrcntr2.dll, which was not found on this system"
What is the problem here?
Answered By 0 points N/A #176812
Hi Erikson,
Please read the whole comment before proceeding.
For the first problem, the solution is actually suggested with the error message. You will have to re-install Nero on your computer. To do this, follow these steps:
  1. Go to Computer
  2. Click on "Uninstall or Change a Program",
  3. In the windows that opens, click on Nero followed by Uninstall
  4. Download Nero from the Internet, you may like to choose from the many sources from which you can download,
  5. Install Nero
This is supposed to solve your problem. If, however, you don't like to re-install Nero, you can do the following:
  1. Download advrcntr2.dll from the DLL FILES Page
  2. Paste it in the default installation directory where Nero was installed.
There is another option if you don't pick these two. You can read this thread in About.com to try to solve this problem.
It is a lengthy guide, so I didn't add it in my already lengthy comment.
